No, that controller is not available on Shnitz.Thank you guys... I'll check it out!! Is the a-j controller not available on schnitz
Thanks for the lead pipefighter ...Found the info.
JOE
A&J Performance
1(908) 289 2000
Joe@A-JPerformance.com
www.A-JPerformance.com
Paypal is:
Sales@A-Jperformance.com
ok!! thanks for the info mate...The a&j system can be used with or without a pc. It actually turns your dry into a wet system. It's good up to a 60 shot without modifications. You can also raise the mid and high bars on you pc before you spray. That takes away from the stealthness though.
...Thank you! I'll have a look at it...Check out MPS racing setup. It will automatically make your injectors go full rich when the button is pressed...a little more up to the rider than the AJ controller...but cheaper too.
