Gahh. I hear this kind of thing from so many novice (mostly American - probably due to the relatively easy licensing requirements) riders. It's like they are all terrified of their front brakes...
I have to go along with Revelis here. The front brake is the only one that really works. At high speed, the back brake is going to do about nothing, except lock up and slip, due to front-end loading caused by your body's inertia and momentum, which is particularly bad on the 'busa with its (more-or-less) 50/50 front/back weight distribution and long wheelbase. The back tire is going to slow the bike down some, forcing more of your body's weight forward onto the forks = less effective braking on the back.
My safety course instructor made us do panic stop runs at 50-60 MPH, where the goal was to briefly (!) lock the front tire. This was some scary shid on the busa, and I could only get it to work the first time; all following runs left me stopped without chirping the tire. He said the secret was to pump the front brake quickly using only your fingers while not moving your arm at all. He had us practice this off of the bike at first. A lot of us (including me) found that this is not an easy thing to do, as you reflexively tend to use your biceps/shoulder in such a movement which can be disastrous at high speeds (using your upper arm can deliver a steering impuse to the forks, which can get you wobbling...)
Another important thing is how you brake when you panic stop. Never just clamp your hand down. A quick jerking-pull to about 25% followed by a smooth, fluid pull to 100% will always be best. My instructor illustrated it with a "braking mantra" BRAY!-kiinnnggg... BRAY!-kiiiinnnnggg...
As with everything else, practice makes perfect
