Did you put oil on them before installation? Most clutches, aftermarket, will make noise. Unless its a God awful grinding or something and as long as you pre lubed them, you'll be fine
Did you put the top hat back on to the basket properly?? you can get it out of line to where the splines dont match up.. loosen all the 10MM bolts move the hat around on the basket you will feel it seat properly.
