Clutch lever cables (Need HELP)
ssincere
Hello:
I disconected the two little cables that go conected to the clutch lever (right on the clip on)and now i cant remember which one goes where. :whistle: They are both black cables one has a white stripe and the other one has a yellow stripe. I don't whant to connect them the wrong way and mess something else up. Can some one look at their busa and let me know how they are connected. THANKS IN ADVANCE.
It doesn't matter which one you connect which to. The Clutch lever acts as an open. Once you pull the clutch lever it then allows the two wires to "connect". Those wires are what will not allow your bike to start unless you pull the clutch lever and the two wires are "connected".
