Chrome fairing grills screens problem
Guclu
TurkishRiders.Org
i tried every heat resistant chemical (300c resistable) but all of them turned milky , the upper parts and the tail parts are ok , but the part which is very near exhaust is a pain
which chemical are you using ?
ImageShack Links Do Not Work
Bansh
I just used 100% silicone? So far no problems
By the way we have the same bike! Black & silver ...the fastest colors
05BUSABLU
1 min apox clear and it stayed clear for all the ones we have done. i get it at wal-mart for like 3 bucks, dual cylinder mix
Guclu
TurkishRiders.Org
i tried every type of silicone , liquid silicone also ,
, which brand did you use ? can you give me a web link ?
thank you so much .
Guclu
TurkishRiders.Org
we don't have wal-mart here in Turkey
but if you can give the link of that product i can search it here , thank you so much .
05BUSABLU
i send ya some if i have to bro....but ill get the brand and stuff in the morning
Don Hardcastle
Busa Ridin' Sailor (ret)
I used a 2 part "metal" putty. You roll it between your fingers, then it gets warm and you can start to feel it harden. When it gets that point, roll it out into a thin strip and press is thru the screen onto the plastic. Let it set for about 30 minutes and it is as hard as metal. No dripping mess, no chance of epoxy running out on the plastic.
Don
MN72Busa
Formerly known as "Zuki"
I used the epoxy putty & than put a small bead of Hi-Temp silicon all the way around. Going on Season 2 with no problems.
ranman
busaless but lovin the weather
when i did mine i also used 100% silicone. but when i went to get it there was all kinds. so i started reading the back of the containers. some only had a service temp. of up to 100 degres and others were higher i found one with a service temp of 400 degres . if you got some with a low service temp it might melt like hot glue. just read the back. good luck
Guclu
TurkishRiders.Org
(thanx for all messages)
