macbusa
2004 busa:
Just installed a full yosh pipe, pc3r , removed pair valve, install blockoffs and did the small airbox mod.
The bike will not idle - runs really rough. Have tried several maps with the same results.
If I disconnect the connector (the black one) from the back of the airbox the idle smooths out , bike runs good - but I get an FI light.
Airbox - I removed the flapper, sealed the actuator hole and plugged hole from pair valve hose.
Put caps on the number 4 and number 1 vacuum lines.
I am going crazy here - any ideas?
