Here is a little more info:
Dynojet Power Commander V Fuel Tuning System for the 2009 Suzuki 1300 Hayabusa
FEATURES:
Reduced size from PCIIIusb (less than half of the size of PCIII)
USB powered from computer (9 volt adapter is no longer needed for programming)
2 position map switching function built in (map switch not included)
Gear/Speed input (allows for map adjustment based on gear and speed)
Analog input (allows user to install any 0-5 volt sensor and build an adjustment table based on its input such as boost or temperature)
With gear position input connected the PCV is capable of allowing each cylinder to be mapped individually and for each gear (for example: on a 4 cylinder bike with a six speed transmission there could be up to 24 separate fuel tables).
Unit has a -100/+250% fuel change range (up from -100/+100%). This allows more adjustment range for 8 injector sportbikes
10 throttle position columns (up from 9 on PCIIIusb)
Enhanced accel pump utility (increased adjustment and sensitivity ranges)
08-09 Hayabusa PC5:
DynoJet Power Commander Suzuki 1300R Hayabusa PC V USB Fuel Tuner 2009 - Tobefast
Tobefast.com Low Price Guarantee
Dynojet Auto Tune kits for Power Commander V
Product Overview
Don’t have a dyno tuning center nearby? Are you more of a D.I.Y. (do it yourself) type? Are you constantly changing parts on your bike? If you answer "yes" to any or all of the questions above, then our Auto Tune kit is for you. The Dynojet Auto Tune kit is an "add on" accessory that can be used with any of our Power Commander V’s. It connects to the PCV with a single cable and requires only a ground and +12 volt connection to be made to install. If your exhaust does not already have one, a "weld in" O2 sensor bung is included.
"Well, how does it work and what does it do for me?"
We have taken virtually the same technology that our patented Tuning Link dynamometer software (for automated Dyno tuning) uses, along with Bosch Wide Band O2 sensors and miniaturized it to be used on your bike, while you ride. Once installed, the Auto Tune kit monitors the fuel mixture (by installing the included Wide Band O2 sensor in the exhaust). It then sends this information to the Power Commander V and automatically corrects it while you ride. Each map that we offer has preset Air/Fuel ratio values included that we find to be the best overall settings. This lets you simply plug in the unit and let it do the work. For Harley Davidson models we ever monitor and adjust each cylinder individually for increased precision as on these models required fueling can vary significantly between the front and rear cylinder. For advanced users that would like to change the Air/Fuel ratios from our baseline they are fully adjustable. Each throttle opening/rpm combination is individually adjustable, so that you can have both fuel economy, during cruise, while maintaining peak output at larger throttle openings. For most models of bikes it is also possible to adjust the Air/Fuel ratios "per gear". This gives you total control of the fueling in every gear and throttle/rpm area if required.
Autotune Listing:
Dynojet AutoTune Kit for the Power Commander V - Tobefast
Just let us know, we can hook you up when you are ready....
08-09 haybusa Fuel Tuning Computers:
Dynojet Power Commanders - Fuel Tuning Computers - Shifters - ToBeFast.com
Team McCoy MotorSports
ToBeFast: Motorcycle, Streetbike, Cruiser and Offroad ? Parts, Accessories and Apparel Superstore
Phone (606) 433-1556
Sales@tobefast.com
