2000 busa with 06 busa engine won't start, only electrical i used from the 06 engine is the coil packs on each spark plug, it wont do anything at all from the start button but it will turn over and try to crank if i jump the two main connectors on the starter relay, the st relay is checking out fine, sidestand switch checks out good for continuity, but where is the sidestand switch relay? Also how can i temporarily bypass the tip over sensor until i can eliminate the problem?
