Brand new 2015 and sometimes it doesnt wanna shift into 1st gear. when this happens if i roll a little bit it seems to slip in. Anyone else dealing with this issue
This issue will slowly get better as you put miles on the bike but will never go away completely. If you downshift through the gears as you slow down it usually doesn't happen. If you coast to a stop and then try to shift down a couple of gears to first it will happen. You may also notice it's easy to miss the 1-2 shift if you don't shift up firmly and this to will improve. I have 40K on mine and she shifts like butter. Synth oil helps but don't switch over until your second scheduled oil change.
