Ok, im at a loss we put my Busa (1397) on the dyno to map a new PC. First run was sad without the PC went to 1100 rpm, found one plug was dead. Changed new plugs and fired it back up. sounded better hitting on all four, Installed the PC and started to map the bike everything was going great untill we got to 7500 rpm then the bike cuts out like its hitting the rev limiter. everytime we make a run same thing 7500 or 8000 grand cuts back. we have changed everything we can think of, PC, ECU, tip over switch, unpluged the kill box for the air shifter, new battery and on charger to see if a voltage drop would cause it, nonthing. checked for loose grounds and bare wires nada. drained fuel and put racing fuel in it. lower rpms runs great sounds great pulls good to 7500 rpm then thats it. If anyone has had this happen please help us out. Thanks
