Unleaded wioll burn out your O2 sensors. If you are racing you need 100 unleaded at least. 93 will e fine for the roads. Always good to add a little Oct boost.(kawiboy11 @ May 21 2007,12:23) What kind of fuel do you guys run with your turbo application? What is the advantages & disadvantages to , let's say using 110 leaded, or using 93 pump gas? I hear 110 is much safer, & you can run more boost?
Thanks
Cody
this is true but I'm assuming you don't plan on riding it much considering the gas prices and where you can find 110.(kawiboy11 @ May 22 2007,16:28) they are setting my bike up to run 110 leaded, they say it's safer & you can run more boost!
stock motor?(Cloud9 @ May 23 2007,09:27) I am running 12PSI on 91 octane... YOU can't get 93 in Denver; 91 is considered premium.
nope...(Jibit @ May 23 2007,04:09)stock motor?(Cloud9 @ May 23 2007,09:27) I am running 12PSI on 91 octane... YOU can't get 93 in Denver; 91 is considered premium.
Well, I won't be taking cross country rides that's forsure! It's alot harder to find that gas, especially where I live! The price is on $5.40 a gallon here for 110 Leaded Sunco, & normal 92 octane here in Omaha is $3.60! With the turbo system , it has strictly become a toy,(Jibit @ May 23 2007,05:39)this is true but I'm assuming you don't plan on riding it much considering the gas prices and where you can find 110.(kawiboy11 @ May 22 2007,16:28) they are setting my bike up to run 110 leaded, they say it's safer & you can run more boost!
sounds like she would be a little on the wild side to ride "cloud9"!(Cloud9 @ May 23 2007,11:52)nope...(Jibit @ May 23 2007,04:09)stock motor?(Cloud9 @ May 23 2007,09:27) I am running 12PSI on 91 octane... YOU can't get 93 in Denver; 91 is considered premium.
JE Pistons, spacer, corrillo rods, intercooled, etc...
RCC Stage II Turbo. I should be able to run 15 PSI with 91 Octane, but I am doing 12 to be on the safe side. I have an LM-1 and she actually runs a little rich under boost.
o i c, that's like a different language to me man!(fstbusa @ May 23 2007,16:28) I run 93 with stock compression with h20 injection and a half bar spring
1 bar ~ 14.7lbs(kawiboy11 @ May 23 2007,06:31)o i c, that's like a different language to me man!(fstbusa @ May 23 2007,16:28) I run 93 with stock compression with h20 injection and a half bar spring
Boosters will work. Also easy to make. Formula is around here sowewhere. not the best thing to use but when you can't get the gas. Always a good idea to keep some in your hump if you can.(Jibit @ May 21 2007,21:47) what about a lead deposit? I only put in 93 but its mostly because I can't find anything else. I was out in Iowa over the weekend and unless I was directly off the expressway I could find anything higher than 90! And that was loaded with Ethanol! I thought octane boosters were crap?
What are you doing for injectors?(hawkwind racing @ Jun. 02 2007,20:29) ALKY
