Ok, i guess I misunderstood. You said that it was a riders school, no racer's, street folks looking to improve their skills.
A performance school is something different. Racer's and wanna be racer's.
We get lots of advanced street guys who take the performance school.
The rear brake is a tool to control your bike. I think it should be mastered not ignored and feared.
You are correct. My point is, the rear brake on a sport bike has no use unless traction is limited. Yes, you should learn to use the rear brake, especially in wet conditions or any time traction is limited.
If you stab at it it's going to lock. If you learn how to judge traction and apply it properly it's nothing to be afraid of.
You are correct, stabbing either brake is sure to lock the tire. However, the only way I know where the limit of traction is to loose it.
People that stomp on the pedal and lock the rear were in trouble before they ever jammed their right foot on the pedal. They panicked, froze and hammered it. It's the last thing they did wrong, not the first or second thing.
You don't have to be in trouble to highside yourself with the rear brake. The bloke who launched himself on Saturday had been using the rear brake with success all day and mid-afternoon he happen to create the proper condidions and his usual squeeze of the rear pedal sent him heavenly without warning! So no, it's not mandatory to be in trouble to get into trouble nor is it mandatory to hammer the brake to create a highside.
I was just saying that if it's a school for novice street rider's teaching them how and when to use the rear brake ought to be covered and practiced on the track. They need to learn how to steer and brake, not just one or the other.
You are correct! They do need improvement with both steering and braking but they don't need to be attempting to steer with the brake. Rich Oliver is the only guy I know of that specializes in teaching to steer with the rear tire. The class is taught on small dirt bikes on a dirt track. I sent my kid to Rich's school and the rusult was great. By the end of the third day Troy says he must have fell at least 400 times. So you crash a lot during the learning process.
Also, I may point out that the pros like Danny Eslick and Josh Hayes use engine compression to step the rear out then modulate the slide with the clutch! They too, leave the rear brake out of the equasion and so should you!
Using both brakes is the same as having integrated braking, except your brain is the control unit and needs to be trained to operate correctly.
You are correct! Using both brakes is no different than using integrated brakes. There are no integrated brake systems that I know of for sportbikes. And most touring bikes or at least the ones I'm familar with come with ABS along with the integrated braking which keeps both ends from locking up. Great idea on the bigger touring bikes, bad idea on sportbikes if you want performance over safety.
