Head And Cam Worth The Money
Discussion in 'Gen II Busa Information' started by RSXtypeS, Mar 10, 2017.
  1. RSXtypeS
    RSXtypeS Registered
    Contests won:
    Is the head and came package worth the money? I have a brocks full exhaust and lowered. I also have a Bazzaz quick shifter. I just need the opinion of a person that has went this route.
  2. Dennis
    Dennis Registered
    Contests won:
    It depends on what you want. I think ported head and cams are generally considered to be worth somewhere around 13-15 hp. I have a buddy that did this over the winter. We'll see what he gains this spring.
  3. RSXtypeS
    RSXtypeS Registered
    Contests won:
    Ok. That's makes sense. I guess I'm trying to see it it's worth $3500. Lol.
  4. Mathewrussell52
    Mathewrussell52 Registered
    Contests won:
    Name:
    Mathew
    That $ might as well go turbo.
  5. ColdBusa
    ColdBusa Take this Jerry, you silly little rodent Donating Member Registered
    Contests won:
    ^this!!!!!!
  6. shade
    shade Registered
    Contests won:
    Head and cams on a gen2 took the bike from 178 stock to 202 at the wheel.
    If you're gonna pull the motor might as well build it for turbo.
    Jake whitebird likes this.
  7. RSXtypeS
    RSXtypeS Registered
    Contests won:
    Everyone keep urging turbo! I want to stay at all motor set up. I just want around 200hp at the back wheel.
  8. RedBull
    RedBull Registered
    Contests won:
    Name:
    Red
    Just a reminder that PirateDiverJeff has never had his motor apart ~ and you can make good power at sea level naturally aspirated with a Gen 2 . . .
  9. RSXtypeS
    RSXtypeS Registered
    Contests won:
    I just had a full alien head brocks exhaust installed. I had it dynoed and mapped. 182hp 108 ft lbs of torque. STD. I have a bazzaz Qs4 quick shifter. I'm lowered 1in up front and 2 inches in the rear. I also have the Street version K&n air filter.
    I must be missing something. I have the 20in alien head. Does the shorter one make more power or something? They should be within 1 or 2 hp right??
    RedBull likes this.
  10. RedBull
    RedBull Registered
    Contests won:
    Name:
    Red
    His Gen 2 is very similar to yours with short stacks ~ his bike was tuned at sea level & you can feel it everywhere . . .
    piratediverjefff likes this.
  11. nosbig
    nosbig Registered
    Contests won:
    Name:
    Shawn
    You also have to remember that jeff is at sea level, that makes a difference. Don't know what elevation your at. Also keep in mind that his bike may have been on a happy dyno. Your guys may be a little stingy. All these things make a difference on the numbers. Unless your wanting a dyno queen then the numbers don't really matter. The important thing is is your bike happy with the tune. Consistent A/F numbers and a nice smooth power arch with no stumbles. Don't get to hung up on numbers that isn't the important thing.
    RedBull likes this.
  12. RSXtypeS
    RSXtypeS Registered
    Contests won:
    Ok. That's makes sense. I'm about 1000 feet above sea level. A few poeple have told me that this guy's a dyno is kind of stingy. From his dyno sheet he is in CA and I'm in SC. About a 3000 mile difference. Lol
    My bike does run strong. To me anyway.
    piratediverjefff, nosbig and RedBull like this.
  13. nosbig
    nosbig Registered
    Contests won:
    Name:
    Shawn
    That's all that matters bro. As long as your bike is happy.:thumbsup::super:
    piratediverjefff and RedBull like this.
  14. POWERHOUSE
    POWERHOUSE Frank Site Sponsor Registered
    Contests won:
    Name:
    Frank
    You can't compare SAE to STD. STD normally will bias the peak numbers in a positive manner, so if you want to make comparos, RSX, get a copy of your dyno chart with the SAE correction factor, you might not like it, but being "happy" or "stingy" as far as dynos go can be a keyboard stroke away. . .
    nosbig likes this.
  15. 202mphbusa
    202mphbusa Registered
    Contests won:
    I have heard of people playing with the barometer on the yno and could get "HAPPY" readings
  16. POWERHOUSE
    Contests won:
    Name:
    Frank
    That is not only true, it is dishonest to the max and easily checked. Just ask for both your "before" and "after" dyno charts showing the run conditions; compare them to each other, and to the barometric pressure recorded on that day by your local weather service. You will easily find out if you are dealing with an honest shop or some schmuck trying to be a hero. The before and after charts are so very important, and so is presenting these results using the SAE correction factor.
    As a dyno tuner, I target air/fuel and hope my corrections result not only in more horsepower and torque, but better and more linear throttle response. Sure, I would like everybody's bike to make 5,000 hp, but it is the drive-ability of the overall tune that is the first best impression any customer appreciates. One other thing - in targeting the correct afr, whatever that bike does, it does, and it is the combination of a number of things a tuner has no control over besides air/fuel.
    todd moyer and nosbig like this.
Share This Page
