Quicker Gixxer
I hooked up the shift light with the Autoshift.... I'm having a couple problems. The launch/upper limit light work fine... but the shift light doesn't come on until the tach is coming back down past my shift point. I set it to 7k to test.....I run to 9k and nothing happens until the RPMs drop off back down past 7k...then the light blinks.
Also...with the Autoshift on...it blows my Signal fuse...killing my dash...and the bike goes into neutral when trying to shift to 2nd. Like a partial shift due to the fuse blowing? I tried going to a 5 amp higher fuse....still blew it.
I'm using a DynoTune CO2 shifter that works great by itself....but hooking the Autoshift into the switch isn't working for some reason.
Anybody had a similar issue...or suggestions?
Thanks..
Thanks..
