OB_Zarniwoop
Well I did the air box mod and while I was at it I reconnected the Pink wire.
Outcome. Lousy performance especially in low/mid range, so I had my race tuners richen up the bike to it's max which is +10 low +10 mid and +10 high, this is the maximum you can go with the Yoshi box. Although greatly improved it is still not as fast as before as I have only managed to clock 210 since the mod.
My race tuner said that if I'd spoken to him before I had done the mod, he would have advised strongly against doing it saying that it is notoriously difficult to dial in FI and ICU without some sort of regulation valve to even out air flow.
He has now ordered a Power Commander II and the pressure regulator and will spend many many hours working out optimum fuel and Ignition maps.
This is gonna cost heaps guys, but once I get the maps I'll post them here. They should be a good starting point for anyone wishing to carry out the air box mod but WILL NOT BE A PERFECT MATCH. Altitude and temp MUST also be taken into consideration, but as I say they will be a good starting point which should save you guys hundreds of $'s in Dyno time.
Fraternal Greetings
Z
Fraternal Greetings
Z
