big...it shouldn't be too daunting for the novice home mech to perform this task...per the shop manual page 2-8 in the "Periodic Maint." section outlines the procedure quite nicely...with the most scarey part being "Cam Removal" (should you need to swap out some shims) which isn't really all that scary at all and is covered in section 3-28...15 minutes of reading and your average DIY type will feel nearly confident and competent...and after post an in depth pictorial tutoring on the subject?...it should be "Just Follow Thew Step-By-Step Instruction/Pictures" childs play.(bigoltool @ Feb. 04 2007,05:58) Sounds like a damn good plan Bill! Unfortunately I haven't had mine long enough to collect any shims as yet. One possible detriment to this plan may be that a lot of folks are just plain not willing to attempt to adjust em themselves! Though they would still get their old shims back from the dealer!
One of the site sponsors has the OEM shims listed for $4.21 each and I have seen them as low as $3.71 each. In the service manual and online I couldn't find any shims listed smaller than 2.30 so that would rule out needing almost half of the shims on your list.(JINKSTER @ Feb. 04 2007,11:06) SIZE ORDER# SIZE ORDER#
1.35 mm 035-200 2.35 mm 035-220
1.40 mm 035-201 2.40 mm 035-221
1.45 mm 035-202 2.45 mm 035-222
1.50 mm 035-203 2.50 mm 035-223
1.55 mm 035-204 2.55 mm 035-224
1.60 mm 035-205 2.60 mm 035-225
1.65 mm 035-206 2.65 mm 035-226
1.70 mm 035-207 2.70 mm 035-227
1.75 mm 035-208 2.75 mm 035-228
1.80 mm 035-209 2.80 mm 035-229
1.85 mm 035-210 2.85 mm 035-230
1.90 mm 035-211 2.90 mm 035-231
1.95 mm 035-212 2.95 mm 035-232
2.00 mm 035-213 3.00 mm 035-233
2.05 mm 035-214 3.05 mm 035-234
2.10 mm 035-215 3.10 mm 035-235
2.15 mm 035-216 3.15 mm 035-236
2.20 mm 035-217 3.20 mm 035-237
2.25 mm 035-218 3.25 mm 035-238
2.30 mm 035-219 3.30 mm 035-239
and here's the link to SUDCO 9.5 Valve Shims Page....
http://www.sudco.com/95valveshims.html
Pretty reasonable to as Suzi OEM shims are about $8 ea. Sudco imports and sells them for $5-$5.50 ea.
L8R, Bill.
and then the guy who's got his busa 1/2 torn apart discovers he needs a 2.25 shim...or a 2.75 shim...and then what?...he's sorta screwed...and we've succesfully defeated the whole purpose of the shim bank...right?...now he cusses me and the freak'in shim bank idea...nope...that's not the sorta thing i'm looking to accomplish here..however..I do agree that we should stock up heavily on the more popular mid-range shim sizes but should also have a few of the oddballs on hand for "just in case"..granted...we may not ever encounter a single valve throughout all hayabusa.org that actually needs a 1.35mm or a 3.3mm shim (and if they do?..they probably have more serious problems than just a valve adjustment issue) but..we should have at least 1 of each of even the low/high spectrum oddballs...especially at the prices you mentioned...it wouldn't hurt...JMHO and L8R, Bill.(jjmetheny @ Feb. 04 2007,07:20)One of the site sponsors has the OEM shims listed for $4.21 each and I have seen them as low as $3.71 each. Also the majority of online sites list only 9 (2.30-2.70) different shims instead of the 25 (2.30-3.50) that are available, which would make me think that maybe those are the most common ones used. In the service manual and online I couldn't find any shims listed smaller than 2.30 so that would rule out needing almost half of the shims on your list.(JINKSTER @ Feb. 04 2007,11:06) SIZE ORDER# SIZE ORDER#
L8R, Bill.
How about both... give me a few minutes(jjmetheny @ Feb. 07 2007,15:55)so we doing this or what![]()
make this a sticky or start a new thread in maintenance and sticky???![]()
