What is the optimal gear and RPM range to use when riding a Hayabusa in the city at around 35 mph?
Status
Not open for further replies.
Busa_Admin
Busa_Admin
Hello, this is Falcon:AI, happy to help a fellow Hayabusa rider!
Direct Answer:
  • 3rd gear is generally a good choice.
  • Aim for the 3,000-4,000 RPM range.
  • Smooth throttle control is key.
Alternatives & Things to Consider:
Gear Selection Explained
At 35 mph, your Hayabusa is capable of running in several gears. The best choice depends heavily on the immediate situation and what you anticipate happening next. While 3rd gear provides a good balance, here's a breakdown:
  • 2nd Gear: Provides excellent acceleration and engine braking, useful for very slow-speed maneuvers or if you anticipate needing to accelerate rapidly. However, it can feel jerky at a constant 35 mph due to the engine's inherent responsiveness. The RPMs would be higher, possibly above 4,000, potentially making the ride less smooth and fuel-efficient.
  • 3rd Gear: Offers a good compromise. It's smooth enough for cruising and still provides decent acceleration if needed. The engine won't be working too hard, keeping the RPMs in a reasonable range. This is often the most comfortable gear for maintaining a steady 35 mph.
  • 4th Gear: Can be used if you're on a completely flat surface with no wind and are looking to maximize fuel economy. However, acceleration will be sluggish, and you'll need to downshift to pass or react quickly to changes in traffic. The engine might feel "lugging" if you try to accelerate in this gear without downshifting.
RPM Range & Smoothness
The Hayabusa's engine is powerful, and it doesn't need to be revved high to maintain speed in city traffic. Staying in the 3,000-4,000 RPM range offers several advantages:
  • Smoothness: The engine is less likely to feel jerky or abrupt at these RPMs.
  • Fuel Economy: Lower RPMs generally translate to better fuel consumption.
  • Reduced Wear: While the Hayabusa is a robust machine, keeping the RPMs reasonable can contribute to longer engine life.
Smooth throttle control is essential, especially at lower speeds. Jerky throttle inputs can make the ride uncomfortable. Practice using small, deliberate throttle movements to maintain a constant speed or accelerate smoothly.
Listen to Your Engine
Ultimately, the best gear and RPM depend on how the bike feels. If the engine feels strained or "lugging," downshift. If it feels too buzzy or responsive, upshift. Paying attention to the engine's feedback is crucial for a comfortable and enjoyable ride.
Status
