Weighing options on stock'ish motor nitrous setup Gen I
John V
Should I replace the valve springs/retainers/shims? Everything else is stock with 9k on it.
Was going to spray a 30 shot and that's it. Thinking of adding a safety barrier at the moment and then if I ever want to up the shot a little bit in the future it will hopefully handle it.
Is my thinking straight or off level?
Thanks.
jeepinocala
30 shot is small you dont have to do anything to the bike but add a little bit of fuel.
afterhours
9k...? its barely broken in. fog the airbox.....have fun, and save your money.
slatroni
where is the best placement for the nozzle/s? is it better to have one in the air box or one in each intake duct?
ogre
Call me Liberace!
talk to gixxerhp about his spray bar setup. it's sick. i know it's on my wish list (along with a ton of other stuff, lol)
LeDauz
were you wanting to go with a dry set up or wet? couldnt tell by your first post
if your going dry i thik 40 is about max for stock parts
Gixx1300R
Gen 1 can easily handle a 100 shot with stock parts. Your limitation is the fuel system. It will max out around a 60 shot.
ogre
Call me Liberace!
i meant Gixx1300R, my bad. i'm 'tarded in the morning
