fastphil73
Ok found the problem with my 2000. Had the same problem as many others on here with rough idle and hesitation at low rpms. Removed the fuel pump after running fuel injector cleaner through it and letting it soak for a couple of days. Found that the fuel pump was so old it looked to be breaking apart. Found lots of dirt and so forth in the compartment with fuel filter. Cleaned the screens and wow what a mess. My question is this, I have had several high performance bikes before with built motors and so on that ran the fuel filter in line. Has anyone tried this on the 99 and 2000 busas. I was going to put a filter on the main line and the return line just to be safe. In theory it should be the same but the filter will be before the fuel pump instead of after. I was also going to remove the screens on the injectors. This would leave the screen in the tank and the one on the fuel pump to catch anything the in line filters did not. What do you guys think, should work right?
