E-ROC
I have no clue! 2007 Hayabusa with 700 miles. New RCC turbo installed. .80 spacer. First time it was dynoed the boost controller was set for 8lbs. I was having trouble with my FI light, so we installed a set of 34lb injectors from Schnitz. Back on the dyno and still having problems. We could not get o-3000rpms dialed in. We pulled the bike back of the dyno,checked for vacum leaks, plugs, loose wiring etc. Decided to switch back to stock injectors to try and eliminate some options. Still ran the same. O-3000rpm breaking up bad,3000-red runs great. Something happen during the exchange, PLEASE HELP.
