PAIR VALVE REMOVAL?
OB_robino
How does one remove the pair valves? Where are they located and what do they look like?
Is this done along with the air box mod.(motorhead)?
I just got my tri-oval Yoshi pipe and it sounds seeerious...but they didn't have the plates to block off the pair...how do I remove them?
Thanks.
i'm the same way...what is the PAIR, where's it located and what's the best method of removal...any help would be great and thanks in advance!
Guys,
With a new 4-1 exhaust, or the Motorhead air box mod, the pair valve is history. If not removed, you will have backfiring. (TMH airbox renders it inoperable) You will find the tubing from the air box to the exhaust pipes
and a "flapper" under the air filter.
THE EASIEST SOLUTION FOR $20.00 USD:
JOHNNYCHEESE@AOL.COM
He will send out the proper blockoff plates and plugs with detailed instructions. He will also offer E-mail technical support, which is worth more than the $20.00
Havabusa
