Need pciiir map for 02 busa
STUNNAH
THE "STUNGUN" IS BACK!&#33
NEED MAP FOR 02 BUSA, SMALL AIR MOD, SIMPLE PAIR BLOCK OFF TUBE ONLY. FI LIGHT COMES ON AND WILL NOT GO OUT IS THAT A PROBLEM OR WHAT. TAKE PC OFF AND ALL RETURNS TO NORMAL NO FI LIGHT.
THANKS IN ADVANCE,
STUNNAH
I would think that you could just use the zero map that comes on the CD for the PC, since you are running the stock exhaust. The pair valve removal will not affect the fuel requirements, since it comes into play after combustion takes place. If you do not have the CD, you can get it directly from...
http://www.powercommander.com
If the FI light is coming on, you really need to make sure that the connectors for the PC are really on there good.
Regards,
SJBusa
DIDN'T NEED A MAP AFTER ALL, THERE IS A PROBLEM WITH SOME OF THE PC3R'S. HAD TO SEND MINE BACK TO DYNO JET THEY CHECKED IT OUT AND THE FI LIGHT CAME ON THEIR BIKE ALSO. THEY SENT ME A NEW ONE AND IT WORKS JUST FINE NO FI LIGHT. NOW I JUST HAVE TO TUNE IT TO MY PREFERENCE. IF YOU HAVE A PROBLEM CALL PHIL AT DYNO JET HE WILL TAKE CARE OF YOU...
