Undo and remove the little allen bolts as Spud said, but to lift the tank, tip the bike upside down and the tank will fall straight down, much easier and you don't need a prop stand either. . . . but be sure to remove the engine oil and fuel first, it can be quite a messy job!
Nah, not chuck…. It’s Arnold Schwarzenegger !!Alright now Chuck Norris...![]()
Hi Guys I want to raise the tank to run some USB cables under it-do I have to remove the side fairings to do this ? seems a bit of a ball ache if true! Thanks
sorry guys its a gen 3
No u need not to do so simply screw the tank up and fix up your cablesHi Guys I want to raise the tank to run some USB cables under it-do I have to remove the side fairings to do this ? seems a bit of a ball ache if true! Thanks
the GEN 3 manual is on here for download. Search it!!!!! Its a wealth of information and a member has already made it availablesorry guys its a gen 3
