Just had a lead acid battery blow up in my face.
BentValve
Alive & enjoying it!
Went to the eye doc, there is some tissue damage but nothing major. He did note that my eyes sure are scarred up...ive been there 3 times now having him pluck stuff out of my eye balls. Once I poked myself in the eye with a screwdriver. The die grinder has gotten me a few times as well.
Yeah, safety glasses are something I need to get in the habit of wearing.
bigdr
Chief Guinness Taster
Now there's an idea...
Are you changing your name to Lucky Jim..?
Glad you're ok BV ..Had the same thing happen to me many years ago....That and welding flash gotta be the sorest thing around..
manatrader
Well about an 1.5 hours ago it happened.
I was working on a regular customer's 1950 Olds, came in for a fuel leak but had been sitting so I had to get it running to find the leak.
Somebody else had tried to start it yesterday and and put the 6V battery on a charger...they did not vent it.
I opened the vents and shut off the charger and smelled the acid.  I should have know better right there but ive taken bigger risks.
 Well I installed my points and needed a boost, turned on the charger and adjusted the Jumper, she pulled a few sparks  and BOOOOOOOOOM!!  I was blinded right away with acid and I just yelled and the help came .
Luckily I was at work and had alot of help, I was litterally soaked in battery acid.  My hand is bruised from a chunk of battery hitting it so hard.
I came home and rinsed out my eyes and body for 30 minutes and called Poison control to get any other information I might need to get properly cleaned up.
That was scary, ive heard stories of batterys blowing up and even worked in a shop where one blew but I was not there that day.
I might as well have blown off a few rounds off my Glock 23 with no hearing protection on because my ears are ringing bad.
Hmm, I think I will start wearing safety glasses more often.  I thank God I was not hurt worse.
I am just resting my eyes for an hour and I am headed back to work.
BV what the hell, you have had your share of things the last couple of months.
Good thing your okay, don't want you to miss the riding season.
hydrabusa
glad you walked out of it...
<!--EDIT|hydrabusa
Reason for Edit: None given...|1144991217 -->
chrisjp
GM of Haya's in the Hills
sounds like that thing reacted just as bad as my wife does wheni tell her that quicken says we out of money....but anyway glad to hear you are ok
Sloto200
Off we go, into the wild blue yonder...
i'm happy to hear that you went to the doc! and your right... safety glasses are cheap... and can be replaced! your eyes cant!
justintime2
What's your story?
If your heading back to work you lucked out bigtime, whew
frisbee
GODSPEED RACING
Damn BV ! Glad you're okay! Wear your Safety gear on and off the bike!
GJoker
Still got love for ya's...
Ditto the above posts.... just glad it wasn't any worse~
cmc8
definitly go with the glasses if you can't see you can't ride. i guess you could still drive a car though. i don't think they use there eyes anyway.
