billyjob007
How to jack up gen 2 with extended 360 single side swing arm
this is what you need, but search for them in your own countryCentral Lift compatibel met Suzuki Hayabusa GSX-R 1300 08-24 zwarte Paddock Stand ConStands Power-Classic
Complete set inclusief model-specifieke adapterplaat Central Paddock Stand voor snel en eenvoudig opvijzelen van de machine 4 dubbele zwenkwielen voor eenvoudig manoeuvreren Afmetingen: lengte 78 cm / breedte 54 cm / hoogte 75,5 cm Maximaal draagvermogen 300 kg bij 17 kg eigen gewicht Ideaal...www.motea.com
They don’t ship to USA and I can’t find one here for saleCentral Lift compatibel met Suzuki Hayabusa GSX-R 1300 08-24 zwarte Paddock Stand ConStands Power-Classic
I don’t have any extra hand jest my wifeI have a Bursig stand, and they work great, but, you don't need one.
Get a roughly 3' long round steel bar in 13/16", 21mm in diameter.
Run it through the lower frame hole.
If the front wheel is in a chock, or on a front forklift/triple clamp stand, and you have a couple extra hands, you can lift the rear, and set each side's protruding bar down on to a jackstand on each side.
It's awkward with the fat tire, but doable.
Nice!
Nicejepp
4 shure
but not that handy to transport
(i´m thinking about how to build it foldable)
so i store it in my garage for every busa i get for maintenance etc.
and when ever a busa comes in
i put it on my bench with that selfmade mid jack.
the only job that is impossible to do is the pulling of the swingarm.
thatfor i have a swiveling double-t-steelbeam under the ceiling + a 500 kg chain hoist to lift busa´s ass
see my yt-video of the engine mounting at a busa
or see my lil garage walk around also as a 2nd yt-video
