SmokeKingOfCali99Hayabusa
How do I fix this issue?.. the little space between the tail and hump?. How to close it up some. Any suggestions?. The black and red bike is my bike.
Great reply and smart remedy there Rubb!@SmokeKingOfCali99Hayabusa Look at yer second pic down from the top. When yer tail section went on its crooked. The gap between hump and tail is bigger on the right than on the left.
The hump is a fixed thing...hooked at the front and latched at the back.
If it were me I would loosen the 4 bolts at the back that hold the tail and the grab bar (if you had one) take out those 4 bolts. Lift the tail section up slightly to close the gap. Place shims (plastic washers) would work best,they are light and you could use the right amount under the 4 bolts. The right side (viewed from the back) will need more shims than the left side in order to be even from what I see in your photo.
Rubb.
Thank you broShave the seat latch on a belt sander a little at a time . ZRX trick from way back
The black plastic @ bottom that attaches to sub frame
Rubb.
Okay great thank you bro! I’m gonna do that appreciate it. Where can I buy those shims(plastic washers)?. And are there any particular ones I should get?.@SmokeKingOfCali99Hayabusa Look at yer second pic down from the top. When yer tail section went on its crooked. The gap between hump and tail is bigger on the right than on the left.
Rubb.
Lol My bike has been in the shop for 2 months that’s why it looks like that.Great reply and smart remedy there Rubb!
I'd be more concerned about the worn out rear tyre than any misalignment in the body work lol.
Smoke King...love yer screen name...Okay great thank you bro! I’m gonna do that appreciate it. Where can I buy those shims(plastic washers)?. And are there any particular ones I should get?.
Hi. Who made the aftermarket tail? Looks like a problem with the mold to me. I would build it up with fiberglass cut, trim to fit. Test mount the parts before you paint!Lowes and Home depot will work. Some bigger autoparts stores. Also Fastenall if you have them.
Okay appreciate it homie I’ll let y’all boys know what’s upSmoke King...love yer screen name...
get them at any hardware store that sells nuts and bolts. Better luck for sure at a place that just sells nuts and bolts (better selection) they are cheap,so get a bunch in different thickness. Take a bolt out,to take with you. The washer should have a hole in it just big enuff for the bolt. Big about the size of what I have pictured for you. When you get in there you may find the original hardware missing. They are washers with a tube attached. There are rubber gromets as well,they may be missing. Those missing parts could be part of yer prob. Those parts can be put together by you if missing.
yer washer size should be about this big... (bigger circle)
the stock parts that may or may not be missing are...20,22,23
I'm thinking they may be missing,cause you prolly didn't do the instal of that aftermarket tail. We can tell you what to buy,or you could order OEM let us know if they are there to start with.
Rubb.
I bought that tail through Rob Bush Motorsports , they are deal for Catalyst. This is there website. They make the fiber glass And that’s facts bro! I did but we didn’t put the hump on, because were didn’t setup my seat latch up with the lock itself . But it’s all good. We gonna get it straightened out. And this is there website iOneMotoHi. Who made the aftermarket tail? Looks like a problem with the mold to me. I would build it up with fiberglass cut, trim to fit. Test mount the parts before you paint!
Okay bro I very much appreciate it. I’m gonna go to either one. Their right down the street from my house .Lowes and Home depot will work. Some bigger autoparts stores. Also Fastenall if you have them.
I think its yer qwik least expensive option. You may have to loosen and tweek the whole tail section to get it perfect. Start at the top,get the tail and hump lined up like you like it, and tweek the rest of the mounting points as necessary. IE: shims,bigger drilled holes,alignment,etc.Okay bro I very much appreciate it. I’m gonna go to either one. Their right down the street from my house .
