help people!!! bike acting stupid
99'busa
that the weird thing. no codes ,no fi light,feels like im in gear and hitting then letting off the throttle. but if you just take off and run through the gears. not beating on it or anything ,feels normal
sounds like only at 10% throttle or less. in other words barely on it but soon as you give it some more juice its fine.
busasha
when i bought the bike it had the m4 system but not a pc.so i thought it would clear up with a good tune
busasha
we leaned it out from 20% throttle and down and helped alittle
busasha
this guy i took it to sounded like he knew what he was doing. built turbo bikes, n.o.s bikes. had road racing bikes tore apart.nice dyno, nice shop.costed me $350
99'busa
might need to go more than. if you feel froggy you can hook it up yourself to a laptop and play around with it BUT KEEP THE ORIGINAL MAP SAVED. Make your changed and "save as" a dif. name so you can switch back anytime you need. I did this awhile back with similar prob.
99'busa
holy crap. thts an expensive tune. how are the plugs.
99'busa
if it just got the pc than the plugs could be bad now.
busasha
i pulled the plugs b4 i took it to him and looked fine.he cleaned the injectors,dyno tune,sync'd throttle bodies,and installed manual chain tensioner for $350
TTownBusa
Unplug the PC3, ride it without it, find out if the map is the cause.
Spudley
Grippin' and Rippin'
Synch the throttles.....that is all. :oldcool:
