- Joined
- Jun 23, 2005
- Messages
- 14,200
- Reaction score
- 171
Well, after losing coolant for all of last year, and not seeing any of it externally, (oh and smelling it in the exhaust) - I finally decided that it was time to tear into it to get it done by the Bash! ;-)
So, I get the head off this evening (OK you perverts - don't say it!)...and there's a good 2 tablespoons of coolant in #2 cylinder....which is the one I suspected all along based on looking at the plugs.
What caught me off-guard was the Head Gasket...this thing is THREE plys! For those who have never seen the OEM gasket, you heard me right...THREE plys!
There seems to be some sort of adhesive between the plys to bond them together. However, when I removed the gasket, one of the plys was already separated...making me wonder if *this* is where the leak started. Anyone else seen this?
A quick inspection of the head and cylinder mating surfaces shows no flaws. I'll try and put a steel to them in the next couple of days.
Anyway, I'm looking to get a Cometic gasket to replace it.
Now, all that said, does anyone have any recommendations for anything else that I should do while I have it torn apart? I plan on checking the valve clearance when I reassemble the cams since I have a little over 12K.
Any tips/tricks for re-assembly? Should I replace the Valve cover gasket? What about other gaskets/washers, etc?
I've done all this with the motor in the bike.
Any thoughts/suggestions would be appreciated!
Thanks!
--Omar
Thanks!
--Omar
