Grounding meaning electrical work?
Grounding meaning smoothing off a cut up undertail?
Grounding meaning laying it down?
If you can give us a little better description of what you need to know, I'm sure somebody would be happy to help you out.
i heard ppl say add addition wiring from the engine casing to the main frame, rectifier to main frame then a wiring from the batt negative to the main frame.,,.
