Ok I did check the parts fich, and my old PDF for A 99. I see the california Model has a vapor canister. that is purged into the vacuum hoses to TB's Where would my 06 go same place? but w/out the canister rite! The reason I'm checking is i stuffed the tank full like i do! and the other day after running hard, filled up, man a few back fires and surging etc. I thought BAD GAS! But B4 I could get turned around to go back it cleared and runs like a zuki from then on. 15 K miles and just the reg oil filter lube and adj done to her!
