N nandobusa Registered Apr 28, 2010 #1 Hello from Spain any of you can tell me if the front axle of the 99 busa is equal to or equivalent to the 2005 busa 54711-33E00 = 54711-42F00 thanks in advance lease: Last edited: Apr 28, 2010
MikeSomething Registered Apr 28, 2010 #2 Yea should be. 99-07 Busa's should have the same forks, calipers, rotors and wheels.
Zoinks! Registered Apr 28, 2010 #4 I would think it would be the same. No body changes and no other major changes, so I'm pretty sure it's the same.
GIXERHP ok, ok...just a wee bit Irish... Donating Member Registered Apr 29, 2010 #6 The size is the same, however, they are different! The 99 to 2001, have external hex, witch you can use a socket on! The 02 to 07 has an internal hex, witch you need a 27mm allen for!
Zoinks! Registered Apr 29, 2010 #7 GIXERHP said: The size is the same, however, they are different! The 99 to 2001, have external hex, witch you can use a socket on! The 02 to 07 has an internal hex, witch you need a 27mm allen for! Click to expand... Good lookin out. Will it still fit? Or does the head mesh differently with the fork?
