Clear Front Turn Signals
Busa04
Can anyone help me? i dont know what to take off or get to to change the front turn signals on 04 busa.
thanks,joey
mzrsq
Busaless
Asked the same question not to long back, here's the , I used bacharles method at the end and it worked great, was easy. but would help if someone was either there to hold nose while you unplug the wiring to the turns, or you may be able to get into there and unplug them before sliding the nose off. The plug is on the left not far behind the turn signal. All in all it's pretty easy and only took me about 1/2 an hour.
Hope this helps
BigBSBusa
Yep, that's probably the easiest wayto do it! The hardest thing is probably getting the lights to fit the opening properly!
