Busa engine sputters when I launch at the drag strip
Albee
My 2000 busa 1397 with walbro fuel pump and regulator set at 44 psi. It is map for VP mr 12.. and has a 12iin. Arm. Gearing 1 down 3 up in the rear. With 200lb rider. Problem is lately when I launch at the drag strip for the first 70 foot bike sputters badly then runs good after it wakes up runs through trap at 145 mph. Please help .
jwcfbd
For some reason the latest replies were submitted as a report to the mods. Here they are.........
Has new fuel filter. Will pull injectors and sent out for service. I'll check engine ground thanks for the input
Okay I will start there with a new set of plugs and check the gap thanks
It's getting plenty of gas
rubbersidedown
TURBO-BUSA-RIDIN'-BASTID
Has anything changed since the last time it ran well?
Did it sit? Diff fuel?
Start with the other mem's suggestions. For me,I'd start with the cheapest and only do one at a time. If you get 5 fixes in hand and install all at once without testing each one you wont get an' exact answer to yer specific problem. Then you wont know for next time,plus cant share the fix with the Org so we can add it to our "issues fixed file." :thumbsup:
Rubb.
rubbersidedown
It would appear we are more concerned about his issue than he is. :laugh:
It happens.
Rubb.
Albee
Rubb.
[/Q thanks I sent the fuel injectors to MPS for service. Should be back next week before test and tune weekend. I will let you know what happens then.thanks
rubbersidedown
Cool. Everything else on the list done or checked out?
Rubb.
Albee
Rubb.
Albee
It happens.
Rubb.
I replaced the spark plug which was burning rich. Got the injectors back from service and set the fuel pressure with vacuum off at 43 PSI before hooking back vacuum. Waiting for next track day to get the results. Will let you know if stops raining here.thanks again.
rubbersidedown
hopefully you are back rocking...:super:
Rubb.
Albee
Okay I'm back to rocking. Done all the suggestions spark plugs injectors.. here was the problem. Finally I plugged off the vacuum to the regulator and set pressure to 43 PSI. Went back to Dino and remapped. Now back the hauling ass. Thanks guys for all your help ☺️
Albee
Power Commander went bad for some reason. Got new power Commander five and remap. Thanks again.
Hayabusa Wannabe
Automotive electronics tend to be fairly robust. At the strip you are creating massive heat and that is the death knell for today's electronics. If you can insulate that unit from heat, it may help its life.
Gen22011
Hey I have a question I have a 2011 Busa what's a good cam head and piston package to go with want to be able to ride it on the street
