ALLshow.NOgo
I just bought this today and hoping for some tips on where to get the power from :-)
(cell phone pics)
(cell phone pics)
Exactly what I did. I also installed a 15 amp fuse right off the battery.I put an outlet under my seat so I could plug things in. I wired it right to the battery so I had to make sure to turn it off or it could kill it.
Just some caution about using that extra connector for a power outlet. It draws power from the 10 AMP low beam circuit. If you overload it by plugging something in that draws too much load, you will lose your low beam when the fuse blows.that connection is for euro models that use the turn signals as running lights.
i'm using it to power my boost and fuel pressure gauges.
good luck with the install
Dang that sucks I already have an aftermarket bulb for the low beam. Thanks for the word of caution man. I may not use that one afterall. I will PM when I am ready to do the install k? thanks.Just some caution about using that extra connector for a power outlet. It draws power from the 10 AMP low beam circuit. If you overload it by plugging something in that draws too much load, you will lose your low beam when the fuse blows.that connection is for euro models that use the turn signals as running lights.
