8.3mm (GaleSpeeds)Randy,
What size stems do your wheels use?
awww link?Here is the thread/post I was looking for.
I may still have the K&Ls at the top of the picture I posted if you want them.
But.. If I was you.... get the Arietes.
awww link?
Mr Bogus I have a set of plain ones if you like you can have them.
Only the rear is angled , the front is straight but a little short.
But they are metal and nice.
They are the ones that came factory on my Marchesini wheels but I wanted black ones instead. I have been trying to include them with the oem wheels I took off but nobody wants those so if you want the stems let me know. I'll post a pic or two here in a bit.
Same things as above Areite stems same as factory Ducati
Ps... I did buy my Black ones form Kurvey girl and they are same as factory Italian Ducati so if you dont want mine you cant go wrong with hers.
let me take a peek at Ricks and see if I can manage a shorter straight one on the back.. The problem with the current long straight ones is that when I check pressure at the track, any little escape of air cost me 1lb.. At only 30 to start with and needing pretty exact amounts, it is a royal pain.. figure an easier to access stem will keep me from wasting time fixing air pressures..Mr Bogus,i am using galespeed type R rims.Using red ARIETE angled valve stems for my black rims.Hope this helps.But mine got to drill bigger holes for them to fit in![]()
