I've had the bike 11 hours now. Can anyone explain, "How to reset the clock in the dash"? Also, where can I look at or purchase a hard copy of the owners manual for a 2001 GSX1300R?
I have a Clymer manual coming from Amazon.
Honestly, i just unhook the battery at noon and hook it back up since it resets to 12:00. i find it easier than digging out the manual and finding the procedure.
if it is the same as my 05, hold down the button just below the clock until the clock starts to blink. then use the same button to advance the clock forward to the correct time. erik
From memory, you press and hold the set and adjust buttons simultaneously until the clock starts flashing. Then you use the adjust to cycle through to set the correct hour then minute.
Thanks! I installed a new low beam bulb. Through the top. Reset the clock. Cleaned lubed and, adjusted the chain.
Polished the D and D noise makers. It's lunch time some where!
had some free time so I GOOGLEd the link for an owner's manual for you (P.S. Service Manual also here for FREE...maybe get that refund from Amazon, eh?)
