I took a break from working in the garage to shed some light in my trailer. Still working on it but here are some pics from tonight's fun:
I installed a couple 48" 2-bulb T-8 fixtures:
Definitely lights up the trailer
I installed a switch and down below will be an outlet; still working on that.
The T-8 fixtures require less power so I'll be able to run the bulbs with a power inverter! (already tested it). I'm going to wire an outlet on the outside of the trailer so I can use utility power or my generator. And I'm also going to pull 12V from the trailer connector to power a power inverter to provide the 120VAC to run the lights.
I'll be working on that in the next few days and will post up more pics....
