So, after putting the aftermarket swing arm on, which is a stock swing arm extended 4 inches...
I also installed the progressive suspension 465 shock....
Now at high mph, around 110-120 + mph i get what feels like an unbalanced tire...
I think its generally when under throttle... though its hard to tell, with the turbo i have to get out of it pretty fast or ill be running cars down...
Anyhow...
I just checked the rear tire, and it balanced out perfectly (using dynabeads in the tire as well)..
My first idea was that i might be getting pogo from the progressive spring, so i added a couple turns to the spring to increase preload...
Now, it seems like my tire hop got FASTER at high mph?
SO i think i have a suspension setup issue, so i'm looking for the pro's to maybe point me in the right direction....
Anyhow...
