The bike won't start.
FI error in the display. It doesn't power up. Apparently I need to buy the power commander "HDREV" to correct it.
https://cart.jetkit.com/p-868-rev-x-tend-and-start-fuel-update-kit.aspx
and this is for a Busa??
then why would you install a Harley rev extender??
Did it crash during the firmware update? If it did you need to reflash it. If you can't it will need to go back to Dynojet to get the firmware fixed.
DON'T INSTALL THE HDREV KIT! It is for a Harley Davidson only! It will do nothing for a Hayabusa.
Will the desktop software allow you to reset even thought it can't connect? I updated the firmware on my PCIII, but I had to use the desktop software. The firmware updater failed and bike gave me an 'FI' code. The firmware update option in the Power Commander tools section of the desktop software flashed my PCIII correctly.
rec'd the kit, reprogrammed and up and running.
