I just installed a Muzzy 4 into 1 on my 2005 Busa today. I removed the Radiator and Oil Cooler before installing the pipe. After Install I replaced all the lines, and two electrical connections. There aren't any leaks at all, but it is overheating. The Fan is not kicking on, which is causing it to overheat.
Does anyone have any idea what is causing this?
Thanks for the help.
