too many toys
Sometimes during moderate to hard acceleration my 07 jumps out of second gear and goes back into neutral. Does the linkage need some adjusting or am I screwed?
If you DIY, you can do this for under $500 and even cheaper if you only undercut second gear..
I did the upshift side of all gears, new gaskets, seals, oil and coolant for under $425
They can also re-weld the dogs ($5 each) and you have better than new
Try a much more firm action when making the 1-2 shift-it likes it,really but if I'm reading this correctly,your already in 2nd and under WOT, it starts to pull then jumps out???? This would require internal repairsAre you the first owner & how many miles are on it?
