Hey guys, Bigjay from australia here. Got a technical question for you. Ok, i have a 09 hayabusa which i just started drag racing. It has brocks lowering links in the back and strapped at the front. Brocks street megaphone 4 into 1 system and brocks clutch mod and cushion kit. Powermod computer ( similar to power commander ). All dynoed at 201hp at the back and 125lbs/ft torque. We have removed about 8 pounds of weight from the back and added a modified brocks brick on the front end at 18 pounds of weight. The problem we are having is torque wheelies in first gear. Now the question..... IS TAKING A LITTLE IGNITION TIMING OUT AT 80 TO 100% THROTTLE AT PEAK TORQUE A BAD IDEA. We are basically trying to flatten the torque curve. The front wheel comes up at around 6 to 7 and with 15 lbs/ft of torque still to comes it goes higher. If we can flatten torque curve at 110lbs /ft it will come up a little but wont keep rising which means staying on the throttle. 18/44 stock wheelbase and foot shifted. Best of 9.49 at 150 mph. Cant get full throttle in first because of wheelies. Please help!!!!!!!! I love racing my bike but this is becoming frustrating.
Thanks everyone..... Jamie
P.S. If you need dyno sheets i can attach
