How to mount Gear indicator
Discussion in 'Electrical Mods' started by Mikael H, May 1, 2010.
  1. Mikael H
    Mikael H Registered
    Contests won:
    How do you mount your gearindicator above the speedo?
    Do you make a bracket or??
    Thank´s.
    Mikael
  2. twotonevert
    twotonevert Member of P.E.A. Moderator Donating Member Registered
    Contests won:
    Name:
    James Wilson
    Some folks have made brackets, I ran the wire behind the gauge cluster and put a little piece of Velcro at the point the gear indicator touches the windscreen. Hasnt moved in over 5000 miles.
  3. DEMMYM
    DEMMYM Donating Member Registered
    Contests won:
    Name:
    MICHAEL
    +1000
  4. Mikael H
    Mikael H Registered
    Contests won:
    ok, thank you!
    To run the wire behind the gauge cluster, how much do I need to remove?
    Mikael
  5. BlueHaya
    BlueHaya I'm outta here!!!! Donating Member Registered
    Contests won:
    Name:
    Rodney
    +1 :beerchug:
  6. twotonevert
    Contests won:
    Name:
    James Wilson
    Remove the wind screen, the inner panel on the left side, and the gauge cluster. Run all of your wiring and put the Gipro wire behind the cluster and put it back. Be careful removing the cluster, you will have two bolts to remove and there will be 2 plastic tabs that go into a rubber grommet, put out slowly and in a straight line, you dont want to break one. Once you put the cluster back in place, it will hold the Gipro in place for the most part, the velcro is just to make sure it does not vibrate around.
  7. Mikael H
    Mikael H Registered
    Contests won:
    I will give it a try, Thank you!
    Mikael.
  8. Mikael H
    Mikael H Registered
    Contests won:
    I have just mounted my gear indicator, no problem :-)
    Do you put a fuse on the red wire by the battery?
    Mikael.
  9. pashnit
    pashnit Site Sponsor Registered
    Contests won:
    Name:
    Tim
  10. Mikael H
    Mikael H Registered
    Contests won:
    Thank´s :-)
    Mikael.
  11. Rhythm
    Rhythm http://www.youtube.com/us Donating Member Registered
    Contests won:
    Name:
    Rhythm
    Custom molded mine and covered with a carbon fiber vinyl.
Share This Page
