Normal thread, lefty loosey... just loosen the pinch bolts on that side (brake side). Of course you will have to remove the calipers, hang them by bungie cords or something, you will have to remove the front fender to pull the wheel out, but that may depend on your setup as well...The axle isn't reverse threaded is it? I put a big bolt that fit in there and then put a stilson wrench on it and couldn't get it to move.
You may have to loosen up the axel while the bike is on the ground, making sure the bike is in gear. Like the guys said, loosen up the two bolts on the lower part of the fork, on the right (front brake lever ) side of the bike.The axle isn't reverse threaded is it? I put a big bolt that fit in there and then put a stilson wrench on it and couldn't get it to move.
Kind of like your head after one of your binges huh?yes, DO NOT loosen the left side pinch bolts or the whole thing will keep spinning...
Whomp..there it is..say..whompI use a threaded coupler from Home Depot. No welding required, dirt cheap, fits perfect.
cheers
ken
Ditto,I got my .89 coupler from Home Depot and works great.I use a threaded coupler from Home Depot. No welding required, dirt cheap, fits perfect.
cheers
ken
5/8 bolt threadWhomp..there it is..say..whompI use a threaded coupler from Home Depot. No welding required, dirt cheap, fits perfect.
cheers
ken
What size?
r8
