what year is the bike
03 busa
power commander
ign module
K&N filter just cleaned last week lightly oiled
spark plugs new 2 sets
15,000
91 or 92 octane i know is the most expensive at the pump
i removed the power commander and still the hard start was there, like not enough force to crank the engine
small box mod
brock hindle gen 3 full sys
i removed the stater look good the shaft looked good not distorded or anything.
what do you mean by timing?
the problem starts when the bike is warm or hot, cold start is good.
Air Intake Temperature Sensor - sits into the airbox on the bottom LH side.
Found this on 1 of our threads and the problems are exactly what you have....... Here is hoping
If it's duff , it could missread the temperature and apply the wrong fueling correction - make it hard to start , particularly when warm.
Mines a 99 and I've moved that to the LH air intake tract tube.
i do have an alarm, scorpio 500, i solve the spark plug problem, ign mod is bad. i removed it and so far #3 is clean again. but the hard start pro still there
i been using the serv man and the seach in forums to solve the problem and i havent find the problem, used my multimeter to check all trhe electrical sys and everything checked good, i'm ging nuts. thinking about getting a hammer and take care if the problem with it lol
