@mabupa
at 2nd
whenever i will find that leaking seal i will try to glue into the crankase housing wall a "standard" seal without that "wreath / lip" that usually grabs into that gap / milled indentation in the crankase´s wall.
as
@c10 wrote in
that post the kawasaki seal has no such lip and my yamaha fj1200 seal is built same way like the kawa. seal is simply plugged in - thats all.
at the moment i have technically no clue if the pressure inside the busa´s gearbox housing is so high that it would press out a seal without a lip.
but if you compare the gearboxes in general, the pressure in the busa´s gearbox housing should not be so high that the seal would be pushed out.
as I said - in the next case of leaks at that seal I will do the test and glue in a standard seal with temp-resistant (180 ° C and higher) silicone.
the main thing with that would be that both, the seal´s inner and outer diameter, fit 100% exactly.
if this, my idea, would work fine
@Kiwi Rider (
) won´t make anymore that big money turnover (pulling the engine and so on - in summ ~ 15 h)
the costs would drop to less then 1/10 of these costs
