Rayabusa0818
Never Forgotten
Have you thought about a new Busa, I think you could reduce your total cost of ownership with one
Good luck getting it ready for the Bash
if you use the loctite, make sure it is not "Gas soluble" I think epoxy or jb just on the outside is weak... you are going to want what ever you use to be in the pressed area.. I have a few methods I use on this stuff but it wont translate well on the net.. (IE,, I take my tubing cutter and put a couple radial knurls on the fitting.. very touchy)THAT'S EXACTLY what I was hoping for
The search for that is on. I got 1.5 days
GOOD LUCK ON ROUND 5....remember i have gas and a match....
hey chris....i have some structural bonding glue that is gas resistant. Works on all metals,glass,plastics or anything you put it on. Its here in the garage, if you wanna make a raod trip. If not call the body shop you deal with they probley got some.. either 3M structural bonding adhesive or my favorite.. Norton Structural adhesive in your case the 1 minute or 5 minute will work...for extra strength go with the 15 or 40. If they dont have it. Finish Masters or any other autobody paint supplier out there will have some. It not cheap thought. 1 tube is about 15 bucks and then you need the 2part gun to shoot it out of.
if that dont work, i can always load the 600 up
I would guess on the conservative side I have maybe 500 quadrajets running around with primary/secondary metering wells jb welded.. (similar product anyway)J B weld!!
I repaired a carb, with it, and it doesn't leak!
we used to weld gas tanks, just start the car and run the tail pipe into the tank..fill it with gas to keep the it cool and start welding on it
