Brake Light Switch
Ansonone
I have a 2006 and would like to install a brake light flasher, but do not know the location of the brake light switch.  If not that, I could also splice into the wire that goes to the brake lights, but too many wires and I don't want to unwrap and check each if there is a shortcut.  Your help is appreciated, because I do not want to remove the entire rear plastics to get to the wires leading to the brake lights if possible.  Thanks in advance.
Yes, I can see some white wires, when I remove the brake lense, but prefer to locate the brake light switch with your assistance.
there are two one on the top and one on the rear set.
I would install it at the light even though there are a few more wires it would be easier and you would stash it in the tail.
Here is a pic of the plug and tail light
here is my switch on the rear set, I dont know if stock is the same or not.
Mine are after market, but it replaces the banjo bolt on the slave.
