BigBadDodge
Why do people feel the need to run they're mouth, and then all of a sudden want to know what you did to make it work or how to fix something?
On the same note people you give advice that has worked prior but then go a different way and wonder why it doesnt work?
Am i alone here on this?
First was a dude running his mouth about how my bike was setup, then hours later beggin me to help him get his running,
then today guy asking about some cummins valve adjustments
my response was "Running a big cam and 110#valve springs i was told to run the factory lash adjustments to avoid kissing pistons, so with your factory springs definately need to run factory specs i made 700hp on this setup with no piston contact spinning 4k rpm and 65psi of boost"
His response-"yea the motor i took out had rings on the pistons from valve contact"
My response-"exactly why risk the money involved with the bottom end, run what is proven"
His response- "well im gonna run the .008 intake and .015 exhaust it should be alright"
What i wanted to respond with- then go ahead and risk it, why even bother asking if you wont listen (insert explectives here)
