Regular Joe
I'm not ready to buy a kit yet, but is there a way I can just cut the mud flap down with out it looking like crap?
Somebody needs a new tire!Cut it!
Stealth
It's kind of like a Tre but works betterWhat's a dremel??
Hey, I was gonna say that!It's kind of like a Tre but works betterWhat's a dremel??
What's a TRE?It's kind of like a Tre but works betterWhat's a dremel??
oooooooohboy, here we go!What's a TRE?It's kind of like a Tre but works betterWhat's a dremel??
A got something for your treWhat's a TRE?It's kind of like a Tre but works betterWhat's a dremel??
+1Also, GO REAL SLOW!!!! Don't cut too close to your desired final shape, instead leave a bit of wiggle room then creep up on your final shape with a couple of metal files and some sand paper. Take your time.
Also, Tin snips work amazing on the Mudflap plastic, much faster and cleaner than the dremel and it offers better control, remember though to go slow.
Another thing I did was create a carboard template of the material to be removed, sketched out my desired final shape then taped it up and used it to gently trace out my final cuts. Flip it over and you can have both sides matching perfectly.
Finally I left a little flap out back to hold my license plate on with, i still use the factory hanger, I just cleaned up the area around it.
